The master cylinder in the Cuda works well, but the gasket allows fluid to leak and made my freshly re-painted MC look pretty bad in less than 2 years.
The gasket seems to fit well and the rubber is "soft / pliable", but I'm going to try and find a replacement gasket.
Some photo's of the numbers on the cylinder are below.
It looks like Dorman might make a range of gaskets.
Any other vendors you know of?
Numbers on the MC are
3699263 R2 on bottom spine
2427 or 2421 on mating flange.
