PRH
That’s ugly!!!
Ugly is right. While I can fix this, along with the spacers I’ve now gotta figure the most economical route: adjustable ball/ball or individual custom pushrods.
Makes complete sense. Especially at a high RPM, oil starving the rockers and valve tips caint be goodI have to think if they had been run ootb, there would have been some oiling related issues from the six that weren’t even close to plugging up the hole in the shaft from that big gap between the rocker and shaft.
I thought that would be a giant leak, low oil pressure problem, some drowned, some starved.Makes complete sense. Especially at a high RPM, oil starving the rockers and valve tips caint be good
I'm not sure what it is, but it ain't right! Nor Good!I thought that would be a giant leak, low oil pressure problem, some drowned, some starved.
It is nowI'm not sure what it is, but it ain't right! Nor Good!
I'd be about pissed off!Not sure you can see in the pictures but the five rockers in a row are more “silver” in color and are the ones I needed to do this to. The other three are slightly darker and we’re fine. Both left and rights needed to be relieved. Also, the darker ones have the oiling hole drilled slightly further into the cup vs the others. All these rockers are USA made Mellings (at least as indicated on the boxes) These came to me as one shipment when I ordered. No idea on age of these but something perhaps changed in manufacturing.
Right On!It is now
Heck yeah... fix it til it's "good and fixed now!"I’ll usually take my time and give “fixing it” a chance with most stuff. If all else fails then I really “fix it” and the problem is fixed as then there’s nothing left of it!
My older MP ones fit pretty darn nice...Does any stamped rocker fit tight on the shaft... Answer is...They don't.
They are held up tight by the push rod/valve to the shaft .
Badass Man! That's getting er done, Correctly! And the way You shared this, I think should go in tech, or how to maybe, due to the Educational Value!Keeping lifter preload within .050”-.090” will require 3 sets of pushrod lengths. No big deal, all three lengths available singular from Manley. Spacers and pushrod order come monday
