dan5354
I got most of my Moog parts from Rock today only to discover that I didn't get the offset bushings I thought I ordered. My question is - how important is it to use them instead of stock type bushings?
When I had my stock upper control arm bushings the alignment shop was unable to give my duster the proper camber. Even at the farthest cam bolt setting.
So yea, pretty important for adding the caster that these cars need to drive nice out on the hiway.
Otherwise they feel kinda "Twitchy"? at speed.
Ok, so the "new" recommended castor/camber settings are for changing performance/tire technology etc... and are just that, "new recommended settings"! The factory service manual had + or - specifications for caster/camber for the given tires or performance level of the time, and the offset bushings allow you to "add" or "subtract" from those +/- specifications to increase the performance level for your car? Said another way, the offset bushings are not to compensate for frame sag or damage done to your car? Or, when an alignment shop cant get your into "factory" specs,or "recommended" specs and recommends the offset bushings its more than likely due to worn standard bushings? ....Im getting dizzy :blob:
Right. If you have some kind of frame sag or damage, that should be addressed prior to any alignment attempt.
But the offset bushings allow for a far greater caster/camber change than what is necessary for just the radial changeover. Most people like the road feel additional caster gives. It's great for good steering "returnability" coming out of a turn and that same force is also what keeps the car going straight down the riad.
With positive caster, you are not just turning the wheels. You are also lifting the front of the car up as well. This is where the returnability and road stability comes from. The force of gravity returning the car back down and the wheel straight at the same time.
All that said, you can get to the point of too much caster, where it feels like the car is going to "fall over" when you take a turn. It's a really strange sensation.
There are other reasons for wandering, besides not having 3.5* caster.
YAHBUT, to what/whos specs was it alligned. And the tape test is only good enough to get it to the alignment shop.
Ok, causes for wandering,with all new high-quality parts are, in no particular order:1)Tires, 2)alignment, 3)Sector-shaft adjustment, 4)roadsurface, 5)atmospheric conditions, 6)rear suspension, 7)shocks, 8)other.
Where oh where do those aggravating smiley faces pop up from?
When I took it to tire discounters I told them to use the "granny" specs on the Skosh chart lol What's sector-shaft adjustment? Also I have air shocks installed in the rear, could that throw it off as well if its not the same psi as when I had the alignment?
Ah, now I understand. I was under the impression that if you needed or were recommended offset bushings you had some type of problem that wasn't allowing a setting to factory specification.Right. If you have some kind of frame sag or damage, that should be addressed prior to any alignment attempt.
