Offset ground 360 crank - how much more stroke?
Rocket
U.S.A.
Curious to know if anyone has offset ground a 360 crank for Chevy 2.0 big end rods. How much additional stroke does one get?
anyone? im curious too.as this was the old hotrod way of increasing cubes
after a few seconds of googling mopar 360 crank offset grinding ....I found this
crackedback
09-12-2013, 03:40 PM
Yes you can do it.
If you took a 2.125 mopar to a 2.000 chevy, you can add 1/2 the difference in diameter to stroke. The 3.58 becomes about a 3.65 stroke. It really doesn't provide a lot.
Probably cheaper to go 4".
Not enough to make it worth the coin, in my opinion, unless some rules package requires it. Just a minor tweak in cam timing can more then make up for the power "vs" a few cubes.
Thanks for all the posts. Missed the old articles in my search.
