Thanks for the update.
I’m planning on 245/60x15 on 8” rims with 4 1/2” back space on my ‘66 Dart . I will have to make sure the clearance is there before mounting the tires on the rims . This will be on an 8 1/4” axle .
I currently have 205/65x15 on 7” rims on the rear 7 1/4” axle . Seems like this should work .
'66 is a whole different ball game, the early A's are very different from the '67-76 versions. If the 8.25" is an A-body version then with the perches at 43" a 4.5" backspace will put those tires very close to the springs. That's better than not having enough backspace though as you can correct with a thin spacer. As for how they fare on the quarters, well, it would be better to ask someone with an early A.
