What are the odds of buying one of these studs/bolts?
What is the function of these?
part of a kit to snug the spring hangers up against the frame and provide room for more wheel and tire. Moves the springs in ABOUT 3/4 of an inch on each side. The original ones were offered by Direct Connection but there are lots of different kits available now.What is the function of these?
The original is pressed in.How is the one in the original ?
Yep it sure is. Put a nut on the threads to protect them, support the shackle next to the head and drive it out - this is not rocket science.The original is pressed in.
Agreed. I made a new stud for the lower shock mount and welded it in. I can do it if you want.Any guy with an engine lathe setup to cut threads could male that in 20-30 min. I would charge $35 at my shop if we were taking on new work.
