fishy68
Tyr Fryr's Inc.
I was considering that, but does the extra length that the oil has to take for the oil to circulate though the filter cause issues? If not I think I'll just install one of those kits because like you mentioned they are cheap. Because those damn filters are hard to change with manifolds! I had some fun changing the oil on my 318 before I decided to throw a 360 in.
I was going to use a stock shorter filter (the Wix 51068 Del mentioned fit with my hooker headers) then a buddy gave me a relocation kit. I replaced the brass fittings with AN type fittings for easier R&R and better sealing and upgraded the hose size to 5/8" so there wouldn't be any restriction (the hose it came with was 1/2" which has an I.D. of 7/16). Have had it on my Cuda for 3 yrs. now (about 6000 miles) and run the crap out of it with no trouble at all. Runs low 12's so if it were going to be a problem it'd have already showed up.
Come to think of it I also de-burred the oil passages in the adapters and I drilled 4 more holes in the factory oil filter plate. Keeps the oil flowing smooth
