[Found!] Oil filter mounting nut/stud/bolt
rumblefish360
I have escaped the EVIL Empire State!
Florida
This here part pictured below, that holds the filter and that plate that goes to the block. Anybody have an extra?
PM me!
Robert: Give Engine Quest in Las Vegas'a call...
Address...: before cylinder heads, they scoured every part..they could find...
SAVE
WEBSITE
2580 N Commerce St, North Las Vegas, NV 89030
There are a few different versions of those...
The worst one is the one with not enough depth on the hex and the sockets keep slipping off, if you get this style, get the one with the wider hex...
Or the one that uses an internal 3/8" square drive is also another good one...
Just don't get the one with the short hex... :icon_fU: :BangHead:
There's a recent thread here about those differences in plates, bolts, and block machining. They aren't all interchangeable. One comment stated that the number of holes in the plate made them easily identifiable. Anyway... Best to finger out which is correct for your block. Good luck
Just want to send a shout out to a pair of good fellas who so graciously sent me free of charge the plates and bolts.
GOOD FELLA ALERT TO ....
mod5v
stroked340
Thanks fellas!!!!
