Mopar Fan
Looks good to me. If you have to change the angle, just loosen the centre bolt and swivle the unit. The only prob with that is you will probably have to install a new gasket. Also when installing headers it might make the job easier if you take off the adopter, then install a new gasket, after you get it all together. Be carefull they are finnicky on leaking. It will be harder to reinstall after the headers are on. On my gasket I put a skin coat of blue RTV on both sides before i put on the new gasket. I think the torque value for the centre bolt is 12-15 foot lbs. Good luck,I hope this helps.
Dave C.
