68383GTS
Where are you guys mounting your filter when using a relocation kit? What type of oil pump are you using. I mounted mine high up on the inner fender.After 20 miles my oil pressure went to 5-7 psi. Do you think it was to much for my stock pump? Should it be mounted lower with a high volume pump? Now I have to pull the engine and replace the bearings and oil pump. Thanks..........
