dusterdood
The Duster Guy
Anyone have any luck with a particular brand?
I have a fresh engine, so seal swelling stuff might not help. I took apart a fresh engine (500 miles) just to freshen it with new bearings. I reused the oil pan gasket, because it was one of those blue silicon ones with metal bolt hole reinforcements. I noticed one of the metal reinforcements was missing, and added a little red RTV there. When I noticed the leak was from this bolt, I retightened it. Bad move. Now it really leaks, 'cause I pushed the gasket out more. I really don't want to pull it out to do the oil pan gasket. So here I am thinking about the type of stuff that stops real main seal leaks.
