Charlesvolare
I freshened up my 360 and got it back in my car today. Everything is good except for a fairly decent oil leak around the timing cover/oil pan. It's not at the corners, it's at the bottom like the pan isn't seated down tight. I used a cork gasket with rubber ends, Mr. Gasket 394, and I torqued the pan to 15 ft-lbs, however one of the bolts that goes into the corner of the timing cover seemed tight so that may not have been an accurate reading. It seems like a lot leaking for that, but I plan on rechecking everything an re-snugging the bolts. Is this something that's somewhat common, would it be worth it to pull the timing cover back off and re-seal it? It's not leaking at the corners and running down from what I can tell, just leaking out from the bottom.
