Oil Pan info needed for Early A
SS Lancer
North Carolina
Does anyone have suggestions or part numbers for a good quality 7 or 8 qt oil pan that fits well with a small block in a 66 Model Dart
Thanks Chris.
You’ll have to modify the k frame for the milodon ones. I’m in the process of doing that right now.
Jake
Thanks Chris.
Are they any aftermarket K members for my 66 Dart ###
If so are they clearanced for after market oil pans.
I don’t believe so. I know you can modify the pan as it hits the corner of the stock frame or modify the frame. I chose the frame because I had one lying around.
Jake
@CPDave has the Milodon road race pan in his '66 Dart (aka the Zebradart)
It required a little trimming of the pan, but could have been accomplished by a little trimming of the K-frame.
A little meaning 2" x 1/4"
If you can afford to let the pan hang below the K, the Kevco might work.
I attempted to go with the milodon 30941 (408 stroker) but waited 3 months and it still wasn't ready to ship. Also as noted, you have to notch the k frame. Not to wild about that
I went with a kevko m302,it is a little deeper than stock and hangs down about an inch more. Nice pan - with traps and gate assembly. And of course, it is cheaper
Need one for Super Stock class drag racing .
Of course the kevko pan is 5 quart pan and with big filter 6 quart capacity...
I have a kevko pan on my 408. Also did the k-member mod. It's ridiculously easy. I highly recommend doing it.
Im using the same pan. I had to trim my K frame on my 65
