K KenZ Well-Known Member Joined May 26, 2006 Messages 116 Reaction score 14 Mar 27, 2010 #1 Will a 318 oil pan from a 68 Coronet fit into a 73 Duster, also with a 318? Thanks, Ken
70aarcuda Master Hoader of SBM Legendary Member Joined Jan 16, 2005 Messages 16,639 Reaction score 5,967 Location las vegas Mar 27, 2010 #2 yes
66plyValiant Well-Known Member Joined Mar 7, 2010 Messages 2,708 Reaction score 138 Location windsor NS Mar 27, 2010 #3 the only small blocks that differ from each other for fitment is the 360 because of the larger rear main cap as far as I know, correct me if Im wrong guys
abdywgn dismantler Joined Jul 30, 2006 Messages 3,666 Reaction score 4,046 Location Darien, Illinois Mar 27, 2010 #4 the 5.2 and 5.9 Magnum use the 360LA sized pan also
hot rod valiant Well-Known Member Joined Jan 28, 2010 Messages 104 Reaction score 10 Location Fennville,Mi Mar 27, 2010 #5 the 360 has larger main bearings, but the rear bearing cap has a smaller diameter oil pan sealing surface.
hot rod valiant Well-Known Member Joined Jan 28, 2010 Messages 104 Reaction score 10 Location Fennville,Mi Mar 27, 2010 #6 did chrysler ever use a center sump oil pan on any of the magnum engines?
K KenZ Well-Known Member Joined May 26, 2006 Messages 116 Reaction score 14 Mar 28, 2010 #7 Thank you. Ken
