oil pan
project360
Tucson
best pan for the $$
need a pan that is even with the k frame. my current pan is a truck pan and is going to sit way to low as my car is almost lowered all the way down.
you truck pan will not fit your car....you need a center sump pan....
i have a 7quart milodon pan for 360 that milodon cut the right front corner 45 degrees to clear k-member it is painted black and only used it on dyno sale for 150. and brand new milodon 340 pan that the also cut corners 45 degree for k member that has never been installed 175.00 if this helps
