Oil pressure gauge
Will_H#24
Levittown Pa.
I got a new instrument cluster bezel for my 69 Dart Swinger and since I have to take the cluster completely out to change the bezel, I want to change to LED bulbs and also how hard would it be to change the oil pressure idiot light to a gauge? Has anyone done this??
I have read a thread that they added an aftermarket oil psi gauge into the Dart cluster after removing the red oil warning light, you need to go into the search forum and type in the correct words to pull up the info.
I was working on doing just that but ended up abandoning the idea and decided just to upgrade to some aftermarket gauges.
The 67 - 72? Dart dash does not have much room behind the oil light (red)
The other gauges have much more room.(blue)
Not saying it can't be done but you might need to open up the back of the cluster housing.
