i have a rebuit 360 that I just started driving. the oil pressure is a little strange cold a idle it's at 80psi when its warm 75psi, but when I'm driving it drops down to 25psi... anybody have this problem
its really not a problem. you want a minimum of 10 lbs per 1000 rpm. as the oil and engine warm up the oil gets thinner. you can switch to a heavier oil . as long as you have around or over 10lbs at idle , the engine will be fine. i know you are expecting more for a new engine. your clearances may be a little loose.
