dartman59
I'm installing an AutoGage 0-100 psi oil pressure gauge, electrical sending unit. Instead of the sending unit that came with the gauge, I want to use the Mopar Part No. 53030493 dual sending unit that controls both a gauge and an idiot light. I have the resistance curve for the Mopar dual gauge unit, but I'm not sure if it is the same calibration as the AutoGage sending unit. That is, I want to make sure that a pressure that reads 50 psi from the Mopar sending unit will also read 50 psi when the AutoGage sending unit is used. I know how to check using a pressure tank and fitting, but I don't have that available! Thanks in advance guys (and gals).
