Rapid Robert
I bought a std vol pump from a member & he included the gasket. should I use it or toss it? I do lightly drawfile to get the mating surfaces flat. thank you for your time. RR
will do, thank you. RRYES you use it.
That gasket is so thin I don't think it would help with any manufacturing irregularities.Six of one, half dozen of the other.
Personally, I've never pulled apart one that had a gasket, so I don't use them going back together. With a high pressure pump it might be a good idea... But I don't think you're wrong either way. Considering the current state of quality control on machining of replacement parts, it's probably not a bad idea.
How's that for a wishy-washy answer?![]()
yes its the thinnest gasket I have ever seen.
The gasket is on the pressure side of the pump, it won't suck air from there.Do you want to draw air or oil into the pump? There is a reason the pickup is at the bottom of the pan.
Use a gasket.
COPPER no good ??Paper thin manilla type gasket only.
Do it. if it makes you feel good.
* true liberal!
I don’t think it makes any difference. Both surfaces are flat, torque it down and go.
I'm not arguing the point, because it is valid. But Chrysler engineers didn't think it was necessary, and that's not a place where "cost cutting" would come into play. Like I said earlier, probably with an HP/HV pump is where it may become more critical.Yeah, actually it does. A Melling engineer said in a webinar that an oil pump needs a gasket. He ought to know and he’s not guessing like some people do.
Get out your mill file...That gasket is so thin I don't think it would help with any manufacturing irregularities.
