Oil Pump Pick up - Clearance to stroker crank??
360duster
Bavaria / Germany
Hi Guys, another question regarding my first stroker big block.....the 440source internal oil pick up does interfere with the 4.25" Crank / rod (440source 512 Kit). I ground the pick up down, now there´s clearance a little more than 0.056" - is this considered enough?
Thanks for your feedback!
We’re u aware that 440 source has another pick up with out the sleeve on it?
Hi! no, i was not aware, will take a look at their site. It seems to be ok now, if in doubt maybe i´ll order the other one. Thanks!
