oil pump pick up tube
unknownsnake
Mason, MI
anyone have the part number or place to get a stock tube for a 440? Doesnt look like the milodon one I have is going to clear that splash pan that goes on before oil pan. Cant think of the proper name right now for the splash pan :eek:ops:
it's called a windage tray and I just uded a milodon pickup on my 383 and everything cleared have you got it screwed in far enough
Trim the tray if needed. Costs nothing.
x2.
It's most important to use the pickup with the matching pan. Some mising sections of windage tray are not abig deal. I put the tray on, then screw in the pickup wit the tray loose. Then it can be moved away from the block to get the pickup in place. Sometimes that's easier with the engine rotated up into it's "in the car" position.
