wigsplitter74
The Mopar Kid
So my very young motor is apart because when the trans came apart it cracked an ear off of the block. Since I'm having a new block machined I had to tear down the motor and I found some rod bearing material. All clearances were spot on, the bearings weren't tight so I have to believe this was an oil control problem. I was using a stock midsump pan and pickup and racing the car. I have now added 1.5" to the pan and am now installing baffles to keep the oil in the sump. I'm wondering if I should also use oil restrictors to keep some more oil to the mains rather than letting it flood the cam and lifters. I run a solid flat tappet cam. I want to know what you guys do to remedy this issue and if I'm on the right track. Any input, especially pics are very appreciated. If all goes well I wana try and run in the young guns race at the nats since I'm 21 and it shoulda went 11's. Thanks FABO!!
