DusterEd Well-Known Member Joined Jan 13, 2005 Messages 190 Reaction score 15 Location Ohio Apr 27, 2013 #1 I need to take off a steering wheel. Its the type for a 73 Dart Swinger with three spokes and three horn buttons on the ends, it has a center but I never dealt with this type before. Any help out there?
bbrroowwnn never re member Joined Nov 27, 2010 Messages 12,466 Reaction score 806 Location Drums, PA Apr 27, 2013 #2 pop the center out...there is a nut under there to take off....shaft and wheel are splined.....26 I believe...1 master spline
straightlinespeed Sometimes I pretend to be normal Joined Oct 21, 2012 Messages 10,630 Reaction score 4,399 Location Uvita, Costa Rica Apr 27, 2013 #3 I believe once you pop off the center, there are 3 phillips screws that hold the horn pads on. Remove that then you can get to the center nut
grassy Well-Known Member Joined Aug 20, 2009 Messages 5,352 Reaction score 86 Location Nova Scotia Apr 28, 2013 #4 ...just did that job...it helps to have a cheapy puller but there are many other ways to pull the steering wheel.. Grassy
DusterEd Well-Known Member Joined Jan 13, 2005 Messages 190 Reaction score 15 Location Ohio Apr 28, 2013 #5 Thanks everybody for the help!
straightlinespeed Sometimes I pretend to be normal Joined Oct 21, 2012 Messages 10,630 Reaction score 4,399 Location Uvita, Costa Rica Apr 28, 2013 #6 So did you get it off ok?
