Old girl is getting some work.
Charger4404spd
Active Member
Tennessee
Well you know how things start off simple and quickly escalate? My intentions were just new carpet and seat upholstery, wanted a new dash pad and instrument cluster.
The dash pad had the usual cracks, this one had a large crack in the middle. The options were to give Just Dashes $800 to restore it, buy a new one and then would have to dye it, or just attempt to repair the old one myself. I chose option 3.
I had an idea to use the foam insulation in a can, didnt know how it would work, but for a couple bucks I'd try it. Worked pretty well. Had to fill and sand a couple dozen times.
Next was to find the material to cover it. Contacted a vinyl supplier for some samples. They had one color that matched very well so I ordered 1.5 yards.
Covering went pretty well (used contact adhesive). The compound corners on the ends were a **** :) All in all I am pleased with the results and I saved a lot of money.
Removed the cluster, diassembled, cleaned and repainted gauge pointers. Polished lenses, installed new bulbs and installed a new bezel from Classic Industries. Didnt want to pay so much for this, but I called a couple places getting quotes to rechrome the plastic and the cheapest was close to $300 and I would still have to tape up and spray the black and argent silver.
Painted the dash frame with SEM and the color match was spot on.
Just finished installing underdash a/c from Nostalgic Air. Will get around to charging up this week.
Waiting on new seat upholstery from Classic Industries ( been on back order for 2 months :(
After that Im going to drive it and enjoy her!
