funnykarman
I used 1x1 18 guage tubing for the frame work for firewall and trans tunnel . It gives you strength so u can hang steering column support bearing and brake petal assembly on it . Wanted to use as much of the stock dash as possible but had to move it out about 2 inches on the face of it , Found a guage pod on Ebay from the DashMan , that would hold 5 guages , four 2 1/16 and one 3 1/2 . made a flat panel and set face of dash 2 inches by using scrap pieces of 2x3 tubing for spacers , and capped the end's creating a smoothe dash , wanted to use OEM dash pad and had to trim bottom edge until it would fit tight . I looked at getting it redone at Just Dashes but $400.00 was the quoted price , I found a plastic cap that would go on it for $100.00 so I will probably go that way . I used one on a friends Demon with good results . To keep with the old school theme I use plain chrome Auto Meter guages , They have a 3 1/2tac that has 8000 rpm on it , this is a 6000 rpm motor . NOTE : after installing roll cage had to modify the dash again , needed to remove it to work on sorting out wiper assemblys . with cage in place could not clear the ends . Did two things , cut end caps off and made removabe ones , I shortened the bottom of the dash a inch to start with but ended up cutting about 5 inches total off the bottom of it , only had about 1 inch of clearance with the firewall moved back .. The tin work was do inhouse my me . Made cardboard patterns and cut them out of 20 guage cold roll sheets . Rolled 1/4 beads on all the panels for keep noise down .
