On going saga of replacing 67 GTS master
buck351
Campton Hills, IL
So years ago when I replaced it I went to the parts store got a master installed it and that was it. Not now. First one the cap leaked. Second one was in a box that said it was a manual brake master but I think it was for power brakes since it was overall much larger and much higher pedal effort. Third one I looked at before taking it and it had a trail of brake fluid from the piston right out of the box. I didn't trust it not to leak so I refused it and they are getting a fourth one.
Picky Picky! Wanting the right part that is not defective! How DARE you!! :glasses7:
So far so good with the fourth one. Bench bleeding was good noticeably easier than the previous one that was physically larger and much harder to push the piston. Installed and have to bleed system next. Picked up power bleeder for this and future brake projects.
