LovetheA's
Well I've been reading through the postings and forums and I've narrowed it down to the Hotchkis adjustables by fox or the Bistein RCD's. My car is a 67 GTS 4 speed. Changes made so far: polyurethane bushings all around including mounting bushings for rear 6 leaf springs.
Boxed LCA, 1.03 torsion bars, 16:1 quick ratio firm feel manual box, I'm running the factory front BB sway bar. Should I but the hotchkis sway bar mounting brackets and have them welded to my LCA's because I bought some boxed ones at a good deal and they didn't have the brackets? Or should I buy the kind that mount differently for potential upgrade at some point to bigger front sway bar? Are these shocks worth the extra money over Bilsteins with what I have done?
Price $780.00 set of 4.
Description
Applications: 1963-1976 Dodge/Plymouth A Body (Dart Demon Barracuda Duster Scamp Valiant) 1970-1974 Dodge Challenger
Take your 1963-76 Dodge/Plymouth A Body or 1970-74 Dodge Challenger to the pinnacle of performance for autocross and track days. Hotchkis-Tuned Adjustable Performance Series Shocks are one of the fastest, easiest and most dramatic modifications you can make to a Mopar, dramatically improving grip, steering response and control. Adjustable Performance Series Shock Absorbers are manufactured by Fox and tuned by Hotchkis engineers to be the ultimate single adjustable shock for of your muscle car. Engineered using the most advanced development tools available, the valving of these shocks was fine-tuned to deliver a smooth, comfortable ride on the shock�s softest setting and a more aggressive, race-oriented ride on its stiffest setting. Developed as part of a balanced system, Hotchkis-Tuned APS Shocks give your vehicle more control and balanced handling, especially when installed in conjunction with a Hotchkis Total Vehicle System. These shocks are made in the USA and are built with heavy duty billet aluminum end caps, polyurethane bushings, and �� hard chrome plated, heat treated alloy shafts, ensuring years of trouble free operation.
Features and Benefits:
Description
- Lightweight, smooth-bore, Type III hard anodized, aluminum mono tube body.
- Application-tuned, smooth riding, digressive disc technology
- 45 levels of rebound adjustment
- Large, non-slip anodized red adjustment knobs, prominent detents at each level
- Black anodized 6061-T6 billet aluminum end caps
- ½” hard chrome plated, heat treated alloy shafts, 100 hour salt spray testing.
- Direct Bolt-In Replacement for OE Shocks
- Made in the USA
