[Found!] One 14" Rallye Trim Ring
I probably have some but they won't be perfect. How bad Is yours?
Here's the bad spot, Roy.
I have an used set I got when I picked up my rim's.
I you cant find one let me know
What width ring for the 14" rims, they are a few different ones.
Take a measurement of the ring face from the bottom lip to the outside flange. That is easy for someone to match up and get you what you want.
My rims are factory. I'm guessing 5.5".
There is different width trim rings for rims.
Ran in to this recently, my Challenger still has its factory 14" ralleys, but missing the rings.
I had a set of extra rings, I got out of the junkyard in the early 80's which fit my first duster.
The rings are about 1" too wide to fit the Challenger rims.
I was wondering if that was a factory trim ring on 66fyssh's wheel. the factory ones I've seen do not have a lip at the wheel face. The ones I've seen just go straight in toward the wheel face and end. I'd get a pic to make sure what your buying will match what you have.
