Sorry, you're right. Only one brake light. I replaced the turn signal switch with one from the help section at vatozone. It looked identical to the one that was on it except the contact wires/rods seemed to have been bent for a better connection, so I did the same to the new one. Do I have to just screw with the contact rods to make a better connection? My dad can't remember what he did 20 yrs ago when he replaced it.
Before I dug into the column, I could stand on the brakes and only the pass side brake light would come on. If I gently moved the turn signal down, the left brake light would come on and the right would go out.lWhen I moved the lever up (to the right), the right brake light would come on and the left would go out. I am clueless when it comes to electrical wiring or diagrams, let alone testing anything. I'm hoping I just hosed up the contact rods/wires on the back of the blinker cam.
