You do pump the gas pedal a few times when cold starting, right?
Do you still get fast idle? I press the pedal to the floor to set the choke and fast idle and crank to start. You may be hurting yourself by the half way to the floor thing.I depress the gas pedal full way to engage the choke. And while cranking, I hold the pedal half way. I try avoid pumping
Pumping squirts gas, which sounds like you need to start cold.I depress the gas pedal full way to engage the choke. And while cranking, I hold the pedal half way. I try avoid pumping
Yes, The carb accelerator pump gives a full squirt of fuel that way.Yes, as soon as the engine starts, the idle is fast (circa 1000/1200 rpm - no tachometer). I let it running 20 or 30 seconds, then I give a brief impulsion onto the pedal, the choke disengage and the idle drops down circa to 650 rpm. The engine doesn't die, the idle is smooth and regular.
You start with the gas pedal fully depressed? I can try that
You probably need a new pump.
I am 61 years old and have owned a lot of carbed - US and european - cars in my life.
None started the same way and I had to find the best procedure to start (hot or cold) for each one.
But with modern injected cars which start immediately, we got bad habits.
I probably forgot that carbed cars are capricious
Anyway, if a forum member who own a fully stock slant-six 1bbl carb can share his cold starting exprience, I'll be glad to read him
all
