A little close up action of the complex reality of the hydraulic roller lifter bores. (A little side note: This block has yet to be cleaned but was wiped down after disassembly with a mixture of STP & Moly wheel bearing grease. I think it may be the best preservative I’ve ever seen. Wear gloves because hand cleaner will not touch it, I had to wash my hands with brake kleen) It would be easier to mass produce a steel top plate that runs front to rear and bolts in through the China walls to duplicate this. Add in the costs of bushing the lifter bores and I'll quote my friend’s advice to me with family matters : “Good Luck With All That”...
