If you read the Mopar Performance Engine Book about it, it goes into detail and even mentions that total (mechanical plus initial) AND vacuum advance may well be over 60* at part throttle cruise and if you see those numbers, it is normal.
This is something I have spent countless hours doing to cars through the years. Running around with a vacuum gauge taped to the windshield with people lookin at me like I was a dumbass.
......the last half of that last sentence could well be true. lol
That's right they tell you the canister only puts in 10 but it actually puts in 20 degrees at the crank.
mderoy340 directed me to a web site on a hot rod forum that shows a pic of someone that fabricated a small plate to limit it which i probably will make.It just sucks you pay four hundred dollars for a distributor with vac advance and you can not adjust it for what you want. Pertronix has a vac that is adjustable and so does mallory.
