No Smog Swinger
Your battery should have about 12.6 volts DC with everything turned off, if you don't have this then everything else is a waste of time. If you have less than 12, slow charge it, or replace it with a new one. If problem persists, check ground straps. After these two things are done, if you still have problems, then proceed to check firewall connections, especially the ammeter ones. Good luck brother.
