Ordered U-bolts too long.
Dodgenut64
MO.
Got my U bolts in today and they are way too long, I guess I didnt catch the length. Can I just put some spacers in between the nut and the shock plate? IM not gonna drive the car anytime soon, just roll it around.
If it ain't a 100 point show car. Why don't you put it together
and cut off the excess. I use a 3 in. cut off tool. Cut the
extra and then use the side of the blade to contuer the end.
Just a thought?
Make sure that you put a nut on there before you cut!! Or put on a die to recut the threads. I marked mine then cut them in my vice with a sawzall.
Correct, with the nut all the way up, I still need another half inch at least.
Most parts stores can get the ones that will work. Mine were too long too but had enough thread. toolmanmike
