Orig Sway Bar Install Help
SgtLee511
Atlanta,Texas
Cant recall how to install my original bar at the K member, need pics. 1972 Duster 340 Original mount at k memeber how the mounts are set. Thanks Eric Atlanta Texas
not at my car atm, but found some pics thru google that have the same set up as my OE bar. Hope this is what you looking for?
Thanks Todlich. Can't get much better than that.
I believe that '70 & up swaybars go thru the k-member and aren't mounted on the front of the k-member.
I believe this last photo is the right one, trying to match the bolt holes is a "b" , thank you all, have a better idea now, took them loose 30 years ago. My memory faded 25 years ago
I was outside working on it and it runs above that radiator cowl brace and then mounts at the k frame below torsion bars, working in the new electronic age saves a bit of a pain. Thank yall great photo
