Belvedere66
I went through all the steps a second time. This time I used my backup regulator. Everything is working 100%.
67dart273 is the man!
Hmm that is interesting . I'm.not super familiar with the pathing, is there a simple-ish diagram to follow how to do this relay trick?I hate to be the bearer of neg news, but you might not have fixed it. you may have a poor connection causing the low blue wire voltage and when you wiggled around changing the regulator, you "wiggled" the connection "good." Keep an eye on it!!
The general problem "most of the time" is the functional path from the battery to the regulator. Generally, that path is battery......starter relay stud..........fuse link...........through the bulkhead on ammeter RED, to and through the ammeter.........on the BLACK ammeter wire........to the WELDED SPLICE........branch to the ignition switch connector--------through the switch..........out the switch connector on IGN2......out into the engine bay through the bulkhead connector (dark blue)............to the ignition system, alternator field, regulator, etc.
The worst offenders seem to be the bulkhead connector terminals, the ammeter, and the ignition switch and switch connectors.
Again, one easy way around this is to (electrically) chop the blue IGN2 after it enters the engine bay, use the bulkhead connector end to feed a bosch relay, and feed the relay contacts through a fuse/ breaker off the starter relay stud. Connect the load contact to the cut engine bay end of the dark blue.
THIS WILL CAUSE the ammeter to "offset" a few amps but it should give the regulator "exact" battery voltage
What would the problem bee when you have like 0,8-1 Volt here?Turn the key to run, engine off. Hook your voltmeter, one probe to the battery positive, other probe to the blue wire on the alternator. You are looking for a VERY low reading, the lower the better. Over 1/2 volt is way too much, and it should be less
Thx i will try to find the loss somewhere, atleast now i have some idea of what to look at.^^I've tried to explain this^^ It's called voltage drop. The pathway (might be slightly different on a pickup) is from the battery---to starter relay "big stud" (junction point) ---------through the fuse link-------to the large red ammeter wire through the bulkhead connector--------to the ammeter--------through the ammeter-----out the ammeter on large black--------to the welded splice---------branch off--------to the ignition switch connector-------through the switch------out the switch connector on "ignition run" IGN1 wire---------back out through the bulkhead connector............into the engine bay, and branch off to feed underhood loads, including the voltage regulator IGN terminal.
EVERY POINT between the dots is a potential for a poor connection and some voltage loss. The bulkhead connector, the ignition switch connector, and the contacts inside the ignition switch are likely the worst offenders.
ANY VOLTAGE loss through that pathway results in low voltage at the VR in comparison to the battery----just like you measured. The voltage regulator tries to maintain nominal 14V AT IT'S IGN TERMINAL. That means when running, the VR is trying to maintain that, and the drop now works "in reverse" so to speak, as now, the battery must be HIGH to maintain the VR IGN terminal at 14. So the overvoltage condition at the battery when charging is equal to the amount of the drop you measured.
The drop is additive, meaning there can be a few tenths in the ignition switch, a few tenths in the bulkhead connector terminals, and so on. The total drop is the amount of overcharge voltage. ANY drop in the grounding circuit is also added to this drop
Think I missed something...If the only real issue you can find with your wiring is the overcharge condition, one easy way 'around' this is to cut loose the underhood loads supplied by the IGN1 line and fire them with a relay. This is a age old problem and affects MANY Mopars with the same setup over the years.
