[PA] Front Suspension - K, uppers, lowers, spindles, drums FS
roughidle
Super Platinum Member
Pennsylvania
I have a '68-'72 v8 K (top and bottom idler arm tabs) with upper and lower control arms, drums and spindles (SBP)FS. Pickup ONLY. The drums measure 10" across on the outside. Not sure if that makes them 10" or 9" brakes. At this time I'd like to sell complete. The drums and brake hardware will probably need replaced. I've not had the drums off, but both sides spin so the spindles should be fine. The lower control arms may need some attention as the ends of the studs were welded to keep them from backing out of the k frame since there were no nuts to be had so I could load the car on the trailer. They should be able to be salvaged if they are ground down and a die ran over them. The one lower control arm looks like it may have been split (see photo). No strut bars. What you see in the pics is what you're buying except upper a arm bolts. Price is $ obo.
