[FOR SALE] PAC Racing Dual Valvesprings By Trickflow 1.46"OD
richmystery116
New York City.
$ 180.00 OBO plus shipping (am located in NYC and can meet for local pickup in Long Island, Brooklyn, Queens).
Located in NYC and am willing to ship FedEx Ground at additional cost.
For sale are a set of PAC Racing by Trick Flow dual 1.46" OD Valve springs with chromoly retainers and 7 degree valve locks. These are new and came with my Trick Flow small block LA heads. I had to replace them since my cam required more spring than these.
Detailed Spec's below:
Product Line: Trick Flow® Steel Valve Spring Retainers
Summit Racing Part Number:TFS-51400423-1
Outside Diameter of Outer Spring (in):1.500 in.
Retainer Material: Chromoly steel
Lock Style:7 degree
Valve Spring Style: Standard
Retainer Style: Standard
Outside Diameter of Middle Spring (in):1.060 in.
Inside Diameter of Inner Spring (in):0.690 in.
Product Line: Trick Flow® by PAC Racing Dual Valve Springs
Summit Racing Part Number:TFS-16893-16
Number of Springs Per Valve: Dual
Outside Diameter of Outer Spring (in):1.460 in.
Coil Bind Height (in):1.050 in.
Damper Spring Included: No
Spring Rate (lbs / in):391 lbs./in.
Inside Diameter of Outer Spring (in):1.075 in.
Inside Diameter of Inner Spring (in):0.794 in.
Valve Springs Coated: No
