Pace Performance Short block
67autocross
A new iron curtain drawn across the 49th parallel
Winnipeg
Has any tried out the Pace Performance short block that they sell? Looks like a 408 based off a 360 for around $2200 but the details a slim on the web site, I'm not sure if its a magnum or LA block. Thanks
I'm going to see if there is a Canadian distributor, seems like a decent price andI have 68cc J heads so it should work good on pump gas.
He's a sponsor here and has a page in the vendors section. Shouldn't be to hard to get up with him on specifics.
He advertised those in his section since he is a vendor and can do so.
Make sure it is a "LA" or a Magnum and what exactly is required to balance the engine.
Says LA 2 bolt main looks like quench style piston reason for open chamber heads
Evening all,
We have phenonimal luck with the BP offerings. Sorry my listing is a little vague. I will post better info tomorrow and clean up the web page. That ones fairly new to the site so it hasn't been edit'd yet. Just sold a custom dressed 408 the other day and the guy loves it. These use scat assemblies fyi.
Part# BPC4080
Cast Crank
Hypereutectic Pistons
Block:
360 “LA” 2-bolt
2 bolt main
Bored .040
Crankshaft:
Cast steel
Pistons:
Hypereutectic
Rods:
Chrysler w/ARP bolts
Head Size / Compression Ratio:
62cc — 9.91:1
64cc — 9.7:1
68cc — 9.4:1
72cc — 9.0:1
Notes
Must use open chamber cylinder heads with this shortblock
And we ship to Canada very reasonable on engines.
