Hey All,
I've been prepping smaller body parts for paint and have run into a couple of different opinions on what I should be doing so I wanted to run them by you experienced folks.
We're down to bare metal on all body parts, so assume we are beginning there.
I've been using AutoBody Master Epoxy Primer as the first step over the bare metal. Reducing it 4:1 and catalyst 4:1. It's spraying great with no drips, runs etc., although that will be sanded over anyway.
Now depending on what paint I want to buy, PPG/Dupont/Nason there are different products from that point to choose.
If I go with PPG paint the "paint store guru" says I need to use PPG Epoxy Primer, PPG hardener, PPG Basecoat & PPG Reducer, & PPG Clear, etc. Basically I need to stay in the PPG Products for everything. That's okay, but I'm confused on the Primer/Surfacer portion of the program. The product number he gave for the Epoxy is the same as the number for the Primer/Surfacer. So am I not just using the same stuff, but maybe a different mix ratio for a seal coat? And if that's the case, why can't I continue to use the AutoBody Master Epoxy with a different mix ratio? I know you generally want to stay in the same product line in case of paint failure...you know who/what to blame for the mess. However, PPG is expensive stuff.
I thought all I had to do was use the Epoxy Primer (reduced & mixed of course,) sand, then do the body filler & putty where needed, sand, Primer/sealer coat, sand, then base coat, sand, then clear coat, sand, sand, sand.
Is that about right??
What about using different Epoxy with different paint manufacturers? Is this a no-no or no big deal?
Seems like everyone you talk to has a different opinion on what I should or should not be using and that's okay except I've already been told incorrect stuff by one of these "paint shop gurus." Also, they are in the end trying to make a sale. A sale of $500 bucks for everything under the sun looks better to them than say a sale of $300 bucks for things I just need to complete the job. I don't know how much of what they are telling me is for the sole purpose of making extra cash.
As always, you're insight is immensely appreciated.
Pam
Pam
