harrisonm
I have been painting cars for 40 years, and I have never painted a stripe. I am painting a motorcycle for a friend, and he wants a 5" wide black stripe on the gas tank and rear tail piece. The parts will be urethane base/clear in yellow with black stripes and clear over everything. From what I have read and seen on TV, there are two ways to do it:
1. Paint the parts with the yellow base coat, allow the allotted time to be able to apply tape, mask stripe area with fine line tape and masking tape and paper, spray the black, wait a few minutes, peel off all the masking, and bury everything with clear. I have heard that I have at least 6 hours to do the striping and still have chemical adhesion for the clear coat. If I use this method, do I need to wipe the yellow off and or tack rag before spraying the clear?
2. Paint the parts with the yellow base coat and spray on a few coats of clear. Wait for the clear to cure enough to wet sand (probably overnight). Wet sand all the clear with about 800 grit sandpaper. Then lay out the stripes and spay the black paint. Then pull off the masking and spray clear on everything. I have never done it, but I have heard that the new clear will completely cover the 800 grit sanding marks. Which way is best?
