Part # for turn signal sockets for sharks tooth.
get dustd
Anyone have the part number for the correct turn signal light socket that 1/4 turns into a sharks tooth grille. I got a stock harness and they dont fit so Im just going to go right to the part number.
Thanks,
joe
I'm working on it. I tried the Dorman parts, but they use a really cheap contact shoe that has NO spring to it. The bulb rattles around in the socket. I took one apart and bent the contacts, but still... When you put a bulb in, the contacts bend and don't work. They probably cheapened them up.
I have my eye on some sockets for a Gran Fury. I'll see if they're any better. A trip to the junkyard might be in order.
Thank you sir. These seem pretty hard to find maybe ill just modify a latermodel socket to work if worse comes to worst
i know if you go to checkers there is a gm socket that fit right in there. i forget the number but id take a picture of the hole and go to checkers and try to match it.
yea thats what im thinking its not like the cars original at all anyways.
