[SOLD] Parting 72 duster slant 3 speed manual
Will 70-72 doors from a Duster fit on a 73-36 Plymouth Duster? In other words, will the body lines match up? Is there a difference in length from one set than the other?
interior upper panel is different
70-72 were steel upper inner panels
73 up had plastic inner upper panels
if you need 73-76 doors i have 2 california doors still near mint
joe
I know that the tops are different, but will they fit and match up?
How much are you looking to get out of the doors?
complete 3 speed setup sold
4 speed pedals sold
taillights and 1 of 2 grilles pending sale
column pending
still available
07-1975 slant six motor turns free will part it out
exhaust manifold
intake manifold
air cleaner
7.25 rear
9" front drum and suspension
front frames
cross-member torsion
firewall and cowl
roof
glass gaskets
front and rear window trim
dash assy with guages
rear seat frames with foam
split front bench seat frame and cushions and seat tracks
split front bench seat hinge covers
2 doors good condition
trunk lid
and more
890 891 torsion bars
slant 6 rotates freely (will disassemble parts if needed) will be scrap soon
front radiator support panels and lower
drivers cowl to inner fender mount
drivers front rocker filler cap
trunk rods
hood hinges
speedometer cable
all wiring harnesses
fuel tank straps and bolts
tail-lamps
2 grilles
front suspension parts centerlink, idler, upper & lower arms
passenger inner fender assy
cowl (will drill for parts needed)
rear bumper and brackets
front bumper brackets
driver and passenger doors
torsion bar frame mount
trunk gutters assy.
roof assembly
front rear and drip-rail moulding sets
front and rear glass weatherstrip and lockstrips
wiper arms and pivots, linkages, motor etc
front and rear seats
pics
[/QUOTE]
still available
  • taillights
  • 2 grilles
  • power steer floor shift column
  • slant 6 exhaust manifold
  • cross-member torsion
  • firewall and cowl
  • roof
  • used glass gaskets
  • front and rear window trim
  • dash assy with guages
  • rear seat frames with foam
  • split front bench seat frame
  • 2 doors good condition
  • trunk lid
  • seat belts set
  • headliner seat belt retainers
  • drip rail moulding
  • 890 891 torsion bars
  • strut rods
  • grille upper and lower supports
  • many patch panel parts
  • complete harnesses front to back
pics available and open to offers :D
as requested for those who pm'd me
I am looking for the clutch pedal and brake .iam am new at this and don't know if ill be abel to respond right away.so thanks
