looks like next week before i will have some back glass mouldings.
i will be at carlisle spaces i26 i27 i28 i29.
if you are there be sure to stop and say hello!
give me a measurement from the center of the glass bottom to start cut left and right.
and a measurement from the top corners down each side to finish cut.
i will draw it out and send you a picture.
From the top corners I need the metal starting 20" down all the way to 17" from the back window lower center line. At least 3" of the body on the outside of the chanel and on the interior side about 2" in (that should be most of the area that the inside metal window trim attaches to.
I hope I made that clear... that last time tried to explain it the replacment could have rusted through. lol Thanks
Do you have the front seat belts that connect to the trans tunnel side? I am looking for the two peices that accept the lap belts and also have a connection for the shoulder belts...
