salinasjoel
Learning Daily
plymouth script from the header panel?
Do you still have the front and rear window gaskets? If so $?Sent you a PM for parts
What would you take for the front and rear window gaskets?Parting out 1968 Barracuda notchback
318 auto floor shift buckets seat 8 3/4 rear
Has all its trim
let me take a look at the condition of it.plymouth script from the header panel?
yes I doHave you got the trim for the vynil roof
Is it decent?yes I do
Yes niceIs it decent?
Has all its trim
I will take a look at the condition of them and get back to youInterested in the 2 pieces of angled bracing that goes behind the rear seat. PM me
I have the front license plate bracket and the steering column cover. Have to check on the rear light.Might be late here but do you still have the front license plate bracket and mounting hardware? Also the dash cover under the steering column and the rear license plate light assy? if so how much shipped to 20910 area code?
is the steering column the same as a 1967 dodge dart, ? if so I'm looking for the upper Sterring column collars to fill the space on my column left from conversion from column shifter to floor shifterParting out 1968 Barracuda notchback
Has all its trim
rear is soldhow much for the 83/4 housing
The whole car is already parted out and on the trailer to go to the scrap yard.How much for whole car
67 is a little different but 68 will workis the steering column the same as a 1967 dodge dart, ? if so I'm looking for the upper Sterring column collars to fill the space on my column left from conversion from column shifter to floor shifter
