Partnumber 2958568!
65dartcharger
Dart Charger 273 Historian
Tavelsjo, Sweden
Anyone on FABO knowing what partnunber 2958569 fits? It's a a under hood wiring harness.
That p/n on a tag on the harness itself or on a package?
If its on the harness, it could be a sub assembly of a larger harness.
The part # you gave isn't listed in any of my books and doesn't come up on dealerconnect.
I couldn't find it either gun. I could probably get it nailed down by seeing it and its connectors... is the lighting and engine together or separate.. etc
The partnumber was on the box. After open it up it's an engine harness. Partnumber tag on harness shows 2958569. The white connector goes to bulkhead connector and the other connector's goes to ECU unit, ballast resistor, oil presure switch, temp sending unit, alternator and choke I think.
Box shows 270 indicatio February of 1970. Mid year intro of something?
Searching on Ebay it looks like it belongs to a 1970 Dodge truck of some kind. The 300 and A100 had Engine wiring harnesses with 2958 *** so I uess it's Close.
Some FABO member who has a Dodge Truck parts catalog?
I don't see an ecu connector, but do see dual field alt connector. The bulkhead connector is different from 70 A or B-body. So 70-72 E-body, 71-72 b-body. Truck? out of my scope but possible I suppose. I do see what you're saying about PN# though on ebay. There is also a 70-71 truck engine harness which has same bulkhead connector. 1969-1971 Dodge Power Wagon D 100 Used Under dash and Engine Wiring Harness | eBay
I have a truck parts book at home. Not sure if it goes back to 69 but it does cover several years. Big Mutha!
I will check when I get home tonight.
should be 70-up with the dual field alt, and prior to 73 as no electronic ignition.
I gotta admit, I never even cracked a truck book open. I have a truck book that old, its at the shop, I'll try to remember to check it tomorrow.
Truck books are cool! They cover HD deisels and packages we never knew existed.
P/N 2958568 is used from 1969 to 72. 318/360 Ign wiring "B" body van only.
You'll find it listed at 8-15-2 in the 69-71 and 72-74 Truck/Van catalog.
Sorry, that one is a dud.
Not used on A100 vans. I checked.
Thanks big time gunbunny!
