Parts wanted
I have a new Mopar balancer for 72 forged equal spread bolt pattern pully. early 340's have one offset hole . This early 340 pully can be identified by the small hole between the bolt holes. I am going to use a Fluid damper and a 69 back pully as recomended by DC for a factory under drive. The fluid damper are 1/2 inch thicker and the 69 back pullies are 1/2 inch shallower plus smaller in diameter . This combo works perfect on a 70 and newer . It keeps the pullies aligned and acts as a underdrive. I also have the springs used . I have two sets I am using the one set for my 497 Purchace also. $125.00 I'll cover up to $25 for the ride I also have fluid dampers with the 69 back pully. $225 I'll cover 25
Thanks for the reply! Giving it some thought, scatching my head! lol..:-k
