72ScampTramp
Scamp Tramp
What do you guys use in your parts washers? Im thinking about making a homemade parts washer. I'm going to rebuild my transmission so I think water based is out.
ive got purple stuff in my parts washer..got it in 2.5 gal jugs from lowes for a good price...![]()
Just good old make you have two headed babies mineral spirits.
The trouble with some solvents and cleaners is what to do with it when it needs to be replaced. Flushing it down the drain is usually a no-no and the auto parts stores don't want it mixed into their recycled oil. I use diesel or kerosene as they can be added to the used engine oil without a problem (so far anyway!) The down side is it doesn't dry to a paintable surface.....you have to remove the residue to get it clean enough to prime. That and the smell....ugh.
Since it was used for decades as a lamp oil, the flamability is at a minimum. It burns but doesn't flash like gasoline. It's not that much different than diesel.Kerosene is really, really flammable. Like flash, whoosh flammable.
....................................................................................................Just mixed some solvent up from stuff i had sitting around, 2 gallons of b-12 chemtool, 2.5 gallons of parts solvent, 1 can aircraft stripper, 5 gallons of diesel lol i used a 30 gallon plastic tub and needed to soak a pair of heads and some other little stuff. Sounds like a lot but just barelt covered the tops of the rockers
