purplescamper
i debating which route to go.. do i take my 833 to a trans shop to be rebuilt locally or would i be better off buying a rebuilt trans from passion.
A good shop like Jamie, at Passon Performance or Wayne at Brewer's Performance, along with any local builder who has gone through the Mopar New Process is likely going to get you into a good rebuild. They are very simple to build, as stated above. I'm piecing mine together from parts. That heim joint linkage above with the serviceable shifter is leaps and bounds better than the stock stuff and will give you a great, positive shift. I like that idea.
Or rebuild it yourself, they are really quite easy to do, the factory service manual has great step by step instructions, put in a bearing kit and new synchro rings and you are set and save a fair chunk of money....
I'm planning on doing a pistol grip as well. Is your car a console or floor? I'm wondering if the pistol grip lever clears a bench. The A body shifters come forward, then backward and kick toward the center of the tunnel more, so when you're on the left side of the shift, it doesn't come too close to your knee.
Another thing that changes with those shifters is the boot. The A body uses an oval boot and all Pistol Grip profile levers are rectangular, where all rectangular profile boots are rectangular on the outside and don't match the floor.
