Duster Drag Car
Anybody running a paxton novi 1500 supercharger on a 440 with 12.5 to 1 compression and a mechanical cam in the 600 lift range and if so, did you lower the compression with spacer head gaskets and did you change the cam? How does your combo run and what kind of hp is it making at what rpm?
